B-Class (W245) Discuss the new B-Class MPV: B200 Turbo, B200 CDI, B180 CDI, B150, B170, B200
ESP Faulty + Limited on 120kmh
Old Mar 22, 2019 | 10:16 AM
Esin Nedim's Avatar
Mercedes Benz B200 CDI (2005) W245
Hello i have bought a Mercedes Benz B200 CDI (2005y) i saw this problem and limited on 120kmh i just reset anything and giving only this error when i do right/left the steering wheel is starting to showing it again someone pleas help me.
Old May 22, 2019 | 08:31 AM
Mihail's Avatar
B180 CDI
Yep, I have the same problem. A diagnostics tool showed a problem with A1695405945, Airbag Ringen or something else. My mechanic told me that part was designed to fail after a certain period and it was something to do with the software. However, I doubt this is the problem and a new one costs EUR 300. My research shows it could be a number of things. I tried turning the steering wheel from all the way left to all the way right several times and evening the tire pressure on all wheels after this restarted all settings and the message disappeared (for now that is). Good luck I will keep you posted if I decide to replace that part.
