Microphone and speaker issue
Old Feb 2, 2023 | 09:05 AM
Shukurov's Avatar
B class 2015 w246
Hey all. got a problem with my BT calls after accidentally pressing "shipment mode" in engineering mode. Command restarted and everything went wrong after that. Car type, settings etc. I have managed to change the car type to B class w 246 and all other settings but cannot get the microphone and speakers to work during calls. Music and radio work as they should, but just when I call or answer, nothing is heard and the person I'm talking to can't hear me either. have tested with different mobiles but the result is the same. Is there something in the engineering mode that needs to be changed or what are the correct settings for handsfree/bluetooth? when i check microphone status in engineering mode it says " microphone 1 disconnected, microphone 2 disconnected".
see under microphone information
My car is a b class 2015 w246 and everything was working perfectly before I made that mistake.
Old May 19, 2023 | 10:50 AM
giovanniu's Avatar
MB B Class 2017
Hi, did you fixed? I have the same problem
Old May 21, 2023 | 05:29 PM
Hey Hoser's Avatar
2013 W246 B250 Sport, 2018 CR-V Touring
I will never try to put car into engineering mode, unless I absolutely know how to put it back, sounds quite dangerous
Old May 23, 2023 | 01:59 PM
giovanniu's Avatar
MB B Class 2017
Any hepfull response?
Old Jun 22, 2023 | 09:31 AM
Robert z's Avatar
CLA 200
Hi
did you find out how to fix the problem?
Old Aug 16, 2023 | 02:19 PM
hej's Avatar
hej
b250 e
Has anyone found a solution
Old Mar 29, 2024 | 07:33 AM
Msg msg's Avatar
W176 2016-2018
Has anybody found a solution yet... please...
Old May 22, 2024 | 01:21 PM
Bozhidar's Avatar
W245
Is there a solution to this yet?
Old Apr 9, 2025 | 04:03 AM
antoiade's Avatar
CLA 220d
Buongiorno, novità da questa esperienza? È stato risolto?
