2012 Class 18" wheel dimensions
Hello all,
The wife and I are going to place an order this weekend on a 2012 C350 SEDAN. I know this is the coupe forum, but figured the wheels should be the same. With that said, of the 2 18" wheel choices...are the dimensions the same? Does anyone know the weight of each wheel?
Assuming they both are, I'm currently in favor of the 7-spoke (simply because I already have an in-law with the 18" 5-spoke). But...if the 5-spoke is wider and/or lighter, then I may have to change my decision.
Thanks in advance.
-Ernest
Thanks in advance.
-Ernest
Hi Ernest have you posted the same question in the sedan section, as there are always at least 10x more people there than on this coupe section, so someone might know the answer.
AFAIK all rims will have weight, PCD, ET or offset and other info stamped on the inside face of the spokes or hub area, so if your able to get a look at them in the showroom that may help
