Dynamic Handling Package
Old Oct 30, 2011 | 08:59 AM
Ryan9095's Avatar
2012 BMW F30 (328i) Sport Line
What exactly is the Dynamic Handling Package? I know it's a special order around $1400 and includes some upgraded wheel? Can someone explain!
Old Oct 30, 2011 | 11:55 AM
anoop's Avatar
2019 Acura RDX
There's some explanation in this article.
http://www.caranddriver.com/reviews/...car-and-driver
I find it surprising that MBUSA doesn't even list this as an option in the car configuration tool.
Old Oct 30, 2011 | 07:15 PM
tharsis's Avatar
C250CDI Coupe
Direct from MB marketing:
The Dynamic Handling package with sports driving mode makes it possible to choose between a comfortable ride and an excitingly sporty drive with a push of a button.
Sport mode also adjusts the firmness of the damping system and boosts accelerator response, enabling you to feel engine response more directly. Regardless of the driving mode you select, the electronically regulated damping system always adjusts to the driving situation and road conditions. This increases the road roar and tyre vibration characteristics and driving safety, particularly the vehicle’s agility.
One part of the dynamic handling package is its innovative sports parameter steering. By changing the steering characteristic, it provides a particularly sporty steering sensation. The vehicle’s lowering by 15 millimetres makes driving around fast curves even more fun.
For further info, one of the componenets is active dampers/active suspension, seee more on wiki http://en.wikipedia.org/wiki/Active_suspension
Old Nov 30, 2011 | 11:43 PM
4maticfan's Avatar
e350
Is the reduced ride height permanent or adjustable with the push button similar to airmatic? I'm wondering if this option is just asking for trouble as most roads in the US are really crummy and infested with potholes. Reduced ride height, stiffer suspension and bigger rims sound like a recipe for disaster on less than perfect roads.
Old Dec 1, 2011 | 10:33 AM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
I thought that DHpkg also come with pedal shift behind the steering wheel and 3 driving mode (instead of 2). Coupe's ride height is already lower then the sedan and I found my C sport sedan is more bumpy compare to my C32 amg.
Also I don't think DHP is airmatic, it might just a value closing device on the shocks to limit the movement of the shock to make it travel less...just like those bike suspension forks that you can adjust the damping...not sure it really lower another 1.5 meter.
Old Dec 2, 2011 | 12:19 AM
4maticfan's Avatar
e350
How does DHP's torque vectoring work? Is it like the 4ETS system on a 4Matic except it only works on the rear wheels, i.e. brake will be applied if left rear starts to slip and more torque will be applied to the right rear simultaneously?
