C350 4matic Coupe Diamond White/Red
Old May 25, 2012 | 06:35 PM
  #126
cavasotti's Avatar
C350 4matic Coupe
Originally Posted by PersianBoi
Sorry the pictures are so big. Thank you cavasotti. I finally know how to post pictures! Would you be able to post the vid of covering the brakes?
it looks a lot better with the black wheels. just have to clean the outer ring more. if I have time tomorrow I will make the video.. my mom is visiting so i have been running all over the place with her.. i will try though..
Old May 25, 2012 | 06:50 PM
  #127
PersianBoi's Avatar
2005 S55 AMG
Thanks man. I am definitely redoing the lip. But do you think it will look better all black? I really don't mind putting in the extra work for the lip. I just mind putting in the work if it does not look good in the end.
Old May 25, 2012 | 08:21 PM
  #128
cavasotti's Avatar
C350 4matic Coupe
i think it looks better with the silver lip. I have mine that way. my lip is half the width of yours though.. I like the way yours look as well..
Old May 25, 2012 | 09:36 PM
  #129
PersianBoi's Avatar
2005 S55 AMG
I wasn't really feeling the lip. So I redid the wheel, and made a better lip. It is now a little thinner. It isn't as sloppy. It looks natural now. I'll post pictures once I'm finished. Btw, I used newspaper this time, and it literally took me 30 seconds. I just stuffed the papers back there until no brake or rotor was showing.
Old May 26, 2012 | 02:47 AM
  #130
paulw86's Avatar
2009 Nissan Maxima SV sport tech
Thanks for sharing. Car looks great. I am looking into a c class coupe and was on the fence about the red I terror but from your pictures it looks amazing with the white. Now to find a black one with red interior since that is my other option...
Old May 26, 2012 | 11:14 AM
  #131
PersianBoi's Avatar
2005 S55 AMG
Old May 26, 2012 | 06:11 PM
  #132
PersianBoi's Avatar
2005 S55 AMG
Cavasotti, thanks for the advice ! I love the wheels
Old May 26, 2012 | 09:15 PM
  #133
cavasotti's Avatar
C350 4matic Coupe
there you go!
Old May 27, 2012 | 12:22 PM
  #134
PersianBoi's Avatar
2005 S55 AMG
Interior shot, just in case anyone would like to see mine....
Old May 27, 2012 | 02:26 PM
  #135
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
that was one expensive beast when new.
as for the wheels... i personally think the black shrinks the appearance of the wheel size.
Old May 27, 2012 | 06:02 PM
  #136
PersianBoi's Avatar
2005 S55 AMG
Yeah, when we bought it in '06, it was pricey. Now with 90K miles, it went down so much in value that I feel it's not even worth selling. I also kind of think the wheels look smaller, but I think they really set the stormtrooper look...my favorite color combo.
Old May 27, 2012 | 08:39 PM
  #137
mis3's Avatar
2004 CLK320
I agree. The black wheels make them looked smaller.
Old May 28, 2012 | 10:56 AM
  #138
Jav_A's Avatar
2015 C300
any tips/tricks u can share on leaving the lip polished while dipping the rest of the wheels?
r u using tape to mask the lip and leaving it on till the job is done? or removing and re-taping after each coat?
I've plasti dipped a couple times before and getting that lip so clean seems kinda hard.
Old May 28, 2012 | 11:24 AM
  #139
PersianBoi's Avatar
2005 S55 AMG
Hey, there are many ways to do the wheels. I'll show you my way, but it isn't really the correct way to do it . First, I cover the brakes, then I tape the lip with electrical tape (should not have the tape for too long, as it can pull some clear-coat off your wheel....ask me how I know ) Btw, throughout my process, I only put tape once per wheel.
Next, I start spraying the spokes only, trying as best as I can to miss where the tape is. I do this for about 3 coats. It is okay if when doing this, a little overspray gets onto the tape. After this, spray the entire wheel, including the taped lip, by a method called "flash spraying" (see video below). Give the lip 3 coats, in one shot. Wait about 45 seconds, and another coat or 2 in one shot. Then, the moment you are done spraying, peel off the tape gently, so as to not accidentally smear off wet the plastidip from the wheel. If you find the you missed some areas. then you can just add a little tape to one small area of the lip. Btw, if you do the wheel while on the car, make sure to get under there, because the bottom of the spokes are not really visible to you. Make sure to cover the whole wheel. Be creative! Hope I helped; Good luck!
Old May 28, 2012 | 01:20 PM
  #140
cavasotti's Avatar
C350 4matic Coupe
ˆ^I did mine the other way around on the first wheel and then I didnt even use tape. I had an old shirt I used to wipe the dip off the lip while wet. So I dipped the outside of the rim first gave it a nice double coat and wiped the dip off the lip. then I kept spraying the inside of the rim avoiding the lip. sometimes I did re-sprayed part of the lip when needed and wiped it off right away.. on the other wheels I didnt even bother taping. used the shirt from the beginning. it is kinda risky to wait for 10 seconds more and the dip bonds to the tape and when you pull it it messes up the whole thing.. my wheels have many coats because I figured it would be easier to pull it off if i have a think layer of dip..
Old Jul 6, 2012 | 05:41 PM
  #141
2012 C250 Coupe's Avatar
2012 C250 Coupe
Originally Posted by cavasotti
Hi Guys, I have been going through the forums for a few weeks and last thursday I picked up my C350 4matic Coupe Diamond White on Red Leather fully loaded. I am in love with the car. Here are some pictures:
Today I plastiDip the lower part of the front bumper and it looks nice. I want to get the wheels powder coated with black on the inside and leave the outside (star and outside ring) polished. I was going to plastiDip but it was just a pain in the *** to mask and the tapes somehow wont stick onto this wheel. Anyone has done any paint job to this wheel and wants to share the results?
Thank you a lot!
Nice car man! I have the same color combination (Diamond White with Red Interior) on my C250 Coupe. I have aluminum trim otherwise it looks the same. I def like the mods you did.. I see you got it at Benzel Busch? haha small world, so did I?
Who sold it to you? My best friend works there?
Old Jul 7, 2012 | 04:48 PM
  #142
cavasotti's Avatar
C350 4matic Coupe
hi man.. I dealt with Orlando and Mike.. nice pick on color!
Old Jul 18, 2012 | 11:06 AM
  #143
2012 C250 Coupe
just plastidipped the grill to look like the new grill from the sport package. it looks way better in my opinion and it should have been blacked out from factory. a few pictures with bad light.. I will get another one at day light tomorrow.. let me know what you guys think.
I thought about blacking out the rear spoiler but I didnt.. maybe I will try another day.
You PlastiDipped the Grill as well? I think the Grill looks great, especially with the front bumper done as well. Like I said before I have the same exact color combo, Diamond White w/ Red interior. I live in Bergen County...would you be interested at all in maybe doing the Grill together or even just talking on the phone quick to explain how you did it?
Did you take the grill off the car to plastidip it or did you just tape everything off and leave it on?
I am thinking of doing the grill black, but glossy, and doing the front bumper but leaving it matte black.
Let me know when you have a chance. We both got them at Benzel Busch we have to stick together! haha
Thanks bro!
Old Jul 18, 2012 | 08:55 PM
  #144
cavasotti's Avatar
C350 4matic Coupe
Thanks bro!
did you get the car already? sure I can help you and we can meet up and get this done.. on a sunday would be great.. let me know
Old Jul 19, 2012 | 12:01 PM
  #145
2012 C250 Coupe
Yea I have the car already. It is going to Benzel Friday for the 10,000 mile service, so I will have it back Friday night. Then I am getting my rear spoiler and side markers painted white.
That would be great if you wouldnt mine helping me out with the Grill/Bumper. I will PM you
Old Dec 28, 2012 | 12:28 PM
  #146
Mike@Vossen's Avatar
Former Vendor of MBWorld
AMG
Sorry for the bump but love the O.Ps color combo and the front bumper mod.
Old Jan 19, 2013 | 12:14 PM
  #147
JohnnyUte's Avatar
C350 4matic coupe
mine is a 4matic. no DHP for me.
A little late to the party, but I'm looking at getting new wheels and want 19s. The problem is, no one makes lowering springs for the 4matic. I can get tires that make them the same diameter as the current 18s, but I'm afraid of getting wheels and it looking like a 4x4. That being said, I've been asked if my car is lowered, too (even by the dealer) so I wonder if the 4matics sit lower? Doesn't make sense but I'd be ok with it.
Old Jan 25, 2013 | 08:29 PM
  #148
ed4's Avatar
ed4
2010 Audi S4, 2013 MB C63
Shot in the dark: were these pics taken at the Sheffield?
  #149
ed4's Avatar
ed4
Car looks ill, BTW
Old Jan 25, 2013 | 09:57 PM
  #150
benzoslayer's Avatar
c250 coupe
hey man car looks great, you may have already answered this but did u use plasti dip for the rims?
