c250 exhaust and clear side marker
2012 C-Coupe
i want a single dual exhaust but seems like i cant find any.... is there anyone with pic that has it??? if so, please show.... any one came out with clear side marker yet??? i dont want to hear that others might fit the car.. i want that actual product that really fits... i dont care about prices... just want it asap! thank you for yall help.
~ no clears out as of yet for the coupe... therefore i had mine professionally painted to kill the eyesore orange. ![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
![](http://i70.photobucket.com/albums/i98/handwax1/2012-06-23182645.jpg)
AFAIK there hasn't been a specific item made as yet that matches what your asking for, all the ones I've seen at the moment are C63 type replacement models.
If you can't wait for something specific to be released, then just get a custom twin tip set made up at a good exhaust shop and transplant it onto the OEM muffler, I've seen at least one example of that and it looked very good, it was composed of 2 x round tips looking alot like Remus tip units.
Also you won't be able to go too large on size of the tips, unless you modify the diffuser but you will get bigger ones in there than the OEM C180 tips
2012 C250 Coupe
Question: Did you leave the bulbs in behind the painted markers? If you take them out I believe you will get a sensor telling you that you're bulbs are out? If you left the bulbs in then does the paint side marker light up?
Let me know if you can.
Thanks!
I have another brand new set of professionally painted white markers if you are interested.
Additionally, I painted the bulbs with high temperature black paint (several coats) and kept them installed behind the painted lens.
Cheers,
Andrew
Cheers,
Andrew
Hi andrew,
I know I am resurrecting an old thread, but I just sent you a PM because my wife has an Artic White C250 and wanted to get some info from you.
Thanks in advance!
Thanks in advance!
2010 E350 Sport
Resurrecting a very old thread, but I wanted to know if you painted the side marker without removing it from the bumper?
I have an Arctic White E350 Sport and want to do the same thing... Any bulb out errors as of now?
i do have an extra new painted set in arctic white for sale if you are interested.
these were professionally painted off of the car and installed without having to remove the front bumper. you simply have to loosen the front wheel well plastic liner to access the backside of the lens and bulb.
cheers!
andrew
The side markers are on ebay.
http://bit.ly/1cHAJEB
http://bit.ly/1cHASb8
~ i left the bulbs in place and applied a couple coats of high temp flat black paint to the bulbs before re-installing. this results in a light glow behind the painted lens at night and no fault codes. i do have an extra new painted set in arctic white for sale if you are interested. these were professionally painted off of the car and installed without having to remove the front bumper. you simply have to loosen the front wheel well plastic liner to access the backside of the lens and bulb. cheers! andrew
2013 Mercedes C350 Coupe
![](http://i996.photobucket.com/albums/af84/mattgid/20131106_140017_zps7de41647.jpg)
I want to paint my calipers red (similar to the red on my trim and seatbelts plus I want those side markers black to match my paint. What is the best way to do this?
