Gears being held extra long in Eco mode?
Old Jul 4, 2012 | 10:31 PM
Jubair Ahmed's Avatar
2013 C350 Coupe 4M
Question Gears being held extra long in Eco mode?
Hi all,
I've noticed something a bit strange for the past little bit and was hoping someone can provide some insight.
Since the summer heat has kicked in I've noticed that whenever the temperature outside is ~28 degrees celsius (~82 Fahrenheit) or higher (aka when the car engine really heats up) that the gears are being held much longer than normal. It's almost as if the car is in Sport mode because going from gear 2 to 3 the rev's hit almost 3000 RPM. Normally the shift occurs at about 1500 RPM.
It seems odd that the shifting of the gears would be impacted by the heat but I may be missing something here here. Has anyone else experience this issue?
Old Jul 5, 2012 | 12:42 AM
u257993's Avatar
2012 Red C250 Coupe, 1969 Ford Mustang Mach 1, 1960 Beechcraft Bonanza
I've noticed that as well but only when just starting out first thing in the morning. It only does it once.
Old Jul 5, 2012 | 08:23 AM
2013 C350 Coupe 4M
Interesting, mine actually works very well in the morning and as the heat kicks up it gets worse.
