Split screen navigation????
Honestly I'm so fraustrated that the MB navigation units will not allow you to set up a split screen setup with directions on one side and a map on the other.
The only time the directions show up is when you're approaching a turn, which is soooo annoying. I'd like to see a list of instructions and change the route based on toll roads or different routes. Like this... http://www.razorianfly.com/wp-conten...t-22.30.49.png If you have any ideas or suggestions or share the same frustration as me, let me know :smash: |
I don't mind it, I think it's fine but it's different for everyone else. I usually just spin the dial and zoom out pretty quickly to see when the next turn is coming then zoom back in. I like being able to put it up on the speedo screen when I want to use the display for something else.
Engineering mode enables "Split Screen Navigation". However, it doesn't show all the upcoming directions. Instead it shows the upcoming exits and your next direction... I will pay attention to see exactly what enabling it did and compare it to my other C250 coupe without the engineering mode for "Split Screen Navigation" enabled.
Originally Posted by Igor1080
(Post 5328257)
