Adding NAV now possible?
There's also a difference in the flash memory capacity of Map Pilots, the first models only had 4 GB and newer ones have 8 GB (since 3/2013 onward). The newest map update for Europe that was published a few weeks ago won't fit completely on the 4 GB devices, but the Content Manager software used for updating allows you to select which countries you want to transfer to the device.
Some guy also found out that you can use the SD card slot on the Map Pilot for map data on 4 GB devices, but it's a bit of a hassle since the Content Manager won't allow you to transfer the data directly to the SD card drive.
