2013 C250 Sports Plus: Shift Speed Dependent on RPM?
Old Apr 11, 2013 | 10:25 PM
Utishi's Avatar
C250
Hi guys,
I have a 2013 C250 Sports Plus and was wondering why the shift speed varies according to the RPM in "Sports" mode. For example, if when you're in "S" mode and accelerating normally, the car upshifts at ~3k rpm. However, if you go lighter on the throttle or if you keep pressing upshift on the paddle shifter, the car may shift at 2.5k or lower rm.
When you perform these 2 different actions, you'll notice that the shift speed, or the drop in rpm, is much quicker in lower rpm than in 3k rpm.
Also when you floor it, shifts seem to be faster...
Why is that?
Old Apr 11, 2013 | 10:38 PM
AV1's Avatar
AV1
C204 C250-CDI
Originally Posted by Utishi
Hi guys,
Why is that?
Not sure entirely but sport mode on any automatic transmission will hold the gear changes for longer on full throttle applications compared to non sports mode or on part throttle applications.
The rate or quickness in the shift speed may be due to the trans protecting itself and slowing the operation down when the revs are higher to avoid damage or excess wear and tear.
