C230 coupe Need headlight
Old Apr 20, 2013 | 01:12 PM
adameyob2010's Avatar
c230 coupe
Hi, I have a 2002 mercedes c230 coupe.
For some reason the left turn signal on the driver side assembly no longer works.
I was told by two different people that I ought to replace the entire assembly. The problem is that most resellers do not distinguish between the kompressor coupe and the 4 door sedans/wagons.
The lights look the same, but are not cross compatible.
So, I need to find a place to buy a new assembly. If anyone here has the original oem driver side assembly for the coupe, I may be willing to purchase it, otherwise I will have to drop 500 bucks to replace both of them with some Halo after markets (which are the only ones I could find on the internet)
Old Apr 20, 2013 | 01:29 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
This subsection is for the C204 2012+ C-Coupes. You might want to try the W203 Section.
Good Luck.
