Advice for removing side markers
Old May 8, 2013 | 12:34 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I tried to remove my passenger side sidemarkers by accessing through the fender liner and the LEDs/Grille. I could get the side closest to the wheel loose but could not reach the front.
Any one have any advice?
Old May 8, 2013 | 06:51 PM
mtxkidd2's Avatar
2013 C250 coupe
pull the bulb out then push it either forward or backwards can't remember which way then pull up the opposite end that you pushed..so if u push it forward lift up the back end or vise versa...can't remember which way but it's simple once u slide it 1 way or the other
Old May 8, 2013 | 10:28 PM
E350 Sport/ML350RWD
Thanks. I'll try it but I couldn't even get my hands in there.
Old May 8, 2013 | 10:43 PM
mtxkidd2's Avatar
2013 C250 coupe
did u pull out all 4 of the little black fasteners out of the fender well...after u pull out all 4 you should be able to get your hands in there after that
Old May 8, 2013 | 10:54 PM
E350 Sport/ML350RWD
Pulled all 4 fasteners but I didn't know about removing the bulb so I'll try that.
Old May 10, 2013 | 11:22 PM
E350 Sport/ML350RWD
Thanks. I finally figured it out.
