bulbs
Old Aug 2, 2013 | 07:46 AM
BeaverMjr's Avatar
2015 C350 Coupe
bulbs
I know there are numerous threads about bulbs, but none fit my situation...
I have the 2013 c250 coupe and hate the fact that when I unlock the car, the parking lights shine yellow. So I want to replace them. I also want to replace the low beams.
Here's what I'm looking to do: The driving lights in the bumper, where a traditional fog light would be, produce a light that is white with a hint of blue. I want to match that color in the driving and low beam lights.
What I've tried so far that was not to my liking: Silverstar ZXE h7 low beams. The light was white, but there was no blue.
Can someone recommend some bulbs to me. I hate having to return bulbs that are not what I'm looking for.
Mike
Old Aug 2, 2013 | 08:45 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I installed the new Momo Corse bulbs for my lowbeams and they look great with the LED strips.
I found these on AMAZON and I am ready to order them. OSRAM is top quality.
http://www.amazon.com/OSRAM-Cool-Blue-Hyper-Pair/dp/B007K5H4E8/ref=sr_1_4?s=automotive&ie=UTF8&qid=1375447473&sr=1-4&keywords=osram+h7 http://www.amazon.com/OSRAM-Cool-Blue-Hyper-Pair/dp/B007K5H4E8/ref=sr_1_4?s=automotive&ie=UTF8&qid=1375447473&sr=1-4&keywords=osram+h7
Old Aug 2, 2013 | 11:42 AM
BeaverMjr's Avatar
2015 C350 Coupe
You linked the ozram cool blue bulbs but you mention the momo course bulbs which you didnt link. whats the difference and which matches the blue of the running lights best? also... any recommendations for parking lights as these are the yellowest and most in need of replacement.
Old Aug 2, 2013 | 05:50 PM
E350 Sport/ML350RWD
I have the Momo Corse and I am happy with them, but I think the Osrams will have more of the blue tint you are looking for. I desperately want to replace the running lights but haven't been able to get my fat fingers in there. Still working on it.
Old Aug 4, 2013 | 02:41 PM
stingbill's Avatar
C250 coupe 2013
My MB dealer gave me some blue bulbs for the running light and they match the fog lights very well ... to remove the bulbs pull on the 2 wires in a straight line they will pop right out .
Old Aug 4, 2013 | 05:38 PM
E350 Sport/ML350RWD
Wow! My MB Dealer threatened to Void my Warranty on my electrical system if I replace bulbs- Your's gives them to you.
Old Aug 5, 2013 | 06:26 AM
BeaverMjr's Avatar
2015 C350 Coupe
Changing bulbs does not void a warranty...not even on a lease. I don't understand your dealer.
Old Aug 5, 2013 | 09:53 AM
E350 Sport/ML350RWD
If a higher wattage bulb is used- it will create excessive heat and can cause damage to the wiring harness. The harness runs all the way through the car to the SAM in the trunk. They told me IF there is any damage resulting from the modification- the $1500 harness and the labor (4-5 hrs at $100 p/hr) would not be covered by warranty and they would Black Flag my VIN in the system.
So...You are correct that they can't void my warranty from switching bulbs, but they can void my electrical warranty due to any damage resulting from the non-OEM/Recommended part. It depends on the dealership- this one was NOT MOD-Friendly.
Old Aug 29, 2013 | 10:15 PM
BeaverMjr's Avatar
2015 C350 Coupe
bulbs
I eventually bought a set of SilverStar 2825 bulbs to replace the parking lights. They are whiter than the stock clear bulbs but are not what I'm looking for. I want a bulb that will produce light that matches the daytime running lights (the bluish lights that are in the bumper where fog lights usually are).
Can someone tell me which bulbs to buy?
Old Aug 30, 2013 | 11:54 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
That's funny. I would have a lawyer all over his ***, as well as the dealer's *** if they ever voided my warranty for replacing a bulb. They would have to prove that what you did solely damaged the electrical system.
Old Sep 1, 2013 | 09:22 AM
BeaverMjr's Avatar
2015 C350 Coupe
Unhappy Lack of info
Since no one has responded to my information request, does this mean that no one knows or that there are no bulbs made that fit the application I desire?
Old Sep 1, 2013 | 02:23 PM
capt_paul's Avatar
Yeah, I guess that no one knows....
In case you didn't notice, others did respond. If that is not to your liking, I guess you are out of luck.
Old Sep 1, 2013 | 07:49 PM
BeaverMjr's Avatar
2015 C350 Coupe
Ok my bad. I missed the replies and the question. I'll look at ebay and see what I can find. Thanks for pointing me in the right direction.
Old Sep 1, 2013 | 08:26 PM
E350 Sport/ML350RWD
Sorry. I thought I pointed you in the right direction with the Osrams for the low beams but missed the running lights. I tried to remove mine and couldn't get my meat nugget fingers in there to remove them. The trick is the bulbs are very noticeable and if you switch to a blueish bulb to get the desired look- you will see the blue bulbs sticking out like a sore thumb when the lights are off. You might want to contact Mike at AZNOptics to see what he recommends. I considered an LED bulb but wanted to make sure it would have a similar light dispersement pattern to the halogen bulb. The yellow lights still drive me nuts to I guess I need to look into this again.
Old Sep 2, 2013 | 08:40 PM
BeaverMjr's Avatar
2015 C350 Coupe
I remember back in the day talking to someone about stealth bulbs. maybe this is what I need. A blue bulb that gets a light coat of silver. I have clear side markers with stealth orange bulbs. maybe a blue bulb is out there. If not why not make a set? am I barking up the wrong tree?
Old Sep 2, 2013 | 09:21 PM
E350 Sport/ML350RWD
I contacted Mike at AZNoptics and he said he has a new type of LED coming out in the next few weeks that would be great in this application. They are 360-degree shine LEDs that will not throw error codes. His quality is top-notch so I'm willing to wait.
