Would I rub on the back with 265/30/19? 19X9.5
Old Feb 26, 2014 | 09:55 AM
r2racer64zl's Avatar
C350 coupe 2012
Hi
I have a C350 coupe. I got CEC wheels 19X9.5 for the back with 35 offset and I am planning to get 10mm spacers to make them 45 offset. I need to know if it will I rub on the back with 265/30/19?
Old Feb 26, 2014 | 11:09 AM
amgboyw204's Avatar
c250 coupe .2012 e550 coupe
Originally Posted by r2racer64zl
Hi I have a C350 coupe. I got CEC wheels 19X9.5 for the back with 35 offset and I am planning to get 10mm spacers to make them 45 offset. I need to know if it will I rub on the back with 265/30/19?
The tire set up is ok but u will rub in the rear with a 35 offset am running a 40 offset in rear with 265 30 tires an sometime I rub over bumps only if am going fast but now that I got my fenders rolled an lowered on h&r super sport spring No more rubbing. So a 45 offset an 265 30 tires should be perfect with no issues
Attached Thumbnails Would I rub on the back with 265/30/19? 19X9.5-image-2316657996.jpg
Old Feb 26, 2014 | 11:26 AM
tl1000r1's Avatar
2003 clk 500 amg
I thought if u added a 10 mm. spacer it reduced ur offset as if u had a 25mm wheel?.....im a newbie so im just trying to get some correct info
Old Feb 27, 2014 | 06:15 AM
paleface's Avatar
C250 Coupe 2011 AMG Package
Better you make the ET above 45. If you can, make it ET 48.
But if u dont lower, i think its fine.
Old Feb 27, 2014 | 06:21 AM
paleface's Avatar
Yap, thats true. Add spacer will reduced the ET.
if he want to make bigger ET, he have to "chop" the ET
Old Feb 27, 2014 | 07:27 AM
bigigg's Avatar
14' CLS550
Hi
If you add a 10mm spacer to a 35et wheel you will now be at 25et..
AMGboy is saying he sometimes rubs with a 40et, so 35 will be worse..
2 options, get rid of the wheels and buy ones with proper offset, or run a slightly stretched tire, 255/30. good luck
Old Feb 27, 2014 | 11:34 AM
amgboyw204's Avatar
Originally Posted by bigigg
If you add a 10mm spacer to a 35et wheel you will now be at 25et.. AMGboy is saying he sometimes rubs with a 40et, so 35 will be worse.. 2 options, get rid of the wheels and buy ones with proper offset, or run a slightly stretched tire, 255/30. good luck
. Agreed
