Difference between C350 - C63 Struts and Shocks?
Old Feb 26, 2014 | 01:00 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I have the 2013 C350 with the sport package. I have the opportunity to purchase a set of almost new C63 struts and shocks. I looked up in the EPC and it is different part numbers for both the C350 and C63.
I am wondering if it is different rebound between the two. I think that it would be compatible with perhaps a firmer ride.
I recently replaced my front sway bar with the C63 one and it made a difference, with the C63 bar being 1 mm bigger in diameter. I also plan to replace the rear sway bar with the C63 one as well
Any inputs are appreciated.
Old Feb 26, 2014 | 08:04 PM
JohnnyUte's Avatar
C350 4matic coupe
Should be compatible, SHOULD, but not a guarantee. My guess is that they're lower and much stiffer than what you'd find on the C350.
Old Feb 27, 2014 | 07:37 AM
Blickling's Avatar
C350 Coupe
C63 is without a doubt a little lower and a little firmer.
