switch from h&r sport to super sport rubbing issues
Wat can I do to fix the rubbing issues it only rubs on the passenger side rear over bumps and rocky roads
My fenders are rolled
Am runing 19 x9.5 "40 offset 265 30 tires
I agree with andrew. The offset is incorrect.
Its not the shock. Shock will help little bit cause its brand new. But your offset is incorrect. Im running with 19" et48. Using 275/30/19 had rubbing if my son and babysitter in the back. Im using eibach prokit spring. And i ask my friend to "chop" the offset 3mm, now im running with 51 offset and its safe. Even my wife in the back with my son and babysitter.
You have to run offset 45 minimum if you want to use 265 tires. If you using offset 40, run with 255 tires.
The car haven't rub over any bumps since they replace the shock yesterday I did some test over the same bumps I use to rub over before The replacement shock an it's zero rubbing
But if the rubbing start again I'll switch to the 255 tires thanks
