HID headlight
Outrageous.
So I'm thinking, is the bulb out? Why does it flicker a bit at the start of the engine and then die out? Maybe the ballast is failing?
I am trying to see if I can just replace the bulb and see what happens, but I see bulbs priced from $24 for a set of two, to $99 per bulb at Autozone, why the huge price differences? Should I spend more for longevity or are they the same? (aside from temp).
Or can I just unplug the ballast and just plug regular bulbs with the stock wiring and call it a day for $30 instead of $600?
Cars that come with OEM fitted Xenon/HID headlights are entirely different from aftermarket HID's. Easiest way to distinguish the difference between the two is if your bulb has a square metal base on the bottom of the bulb which would be OEM.
Anyways, to answer your question - no. The bulb more than likely works just fine, but, being a Mercedes, electronics run off a Canbus system. They detect if components are using less than a pre-determined amount of voltage, hence why you're receiving the headlight error. If it flashes and turns off on start up, it is more than likely a lack of voltage being sent by the stock wiring of the vehicle. The easiest fix, and typically the best fix to this is to buy a HID harness and wire the lights to your battery instead of piggy-backing off of the factory wiring for headlights. Being that the previous owner more than likely bought some cheap eBay kit, this is guaranteed to be the problem.
