Front and Rear C-Class Two-Piece Rotor Big Brake Kit Package
Old Jun 6, 2014 | 06:30 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
RacingBrake is proud to offer a complete front and rear BBK package for your Mercedes C32. MBWorld members recieve free shipping to the lower 48 states using coupon code MBW-SHIP!
Front
Front and Rear C-Class Two-Piece Rotor Big Brake Kit Package-2170-k-2_zpsdf1d17c5.jpg
  • 2)Forged 6061-T6 aluminum calipers
  • 2)Two-piece rotors 328x28mm
  • 2)Street performance brake pads
  • 2)Adapters
Rear
Front and Rear C-Class Two-Piece Rotor Big Brake Kit Package-06f02772-6410-44c3-8ff7-a31842229c32_zps7fbda6bd.jpg
  • 2)Two-piece rotors 330x22mm
  • 2)Adapters
  • Set of stainless steel brake lines
    Rear Hats have a iron sleeve insert to allow them to be fully compatible with OE E-Brake.
    Please note:
    Rear spindle may require dust shield to be bent/cut or removed
    and have the back plate edge trimmed for before installation to avoid interference.
    Complete Front and Rear Kit
    3,390.29 with Free Shipping to the lower 48 states using coupon code
    MBW-10
    Local pick ups are eligible for CA sales tax waiver
Caliper Features
Caliper Body
Made of forged 6061-T6, Light weight at only 6 Lbs fully loaded.
Internal Dust Seal
Our dust seal is built-in (instead of external boots) uniquely designed to shield the dust and foreign material from contamination
Hardware
Brake pad pins and banjo connections were re-designed for easier brake line connection and brake pad replacement.
Surface Coating - Powder coating with most durable finish for lasting appeal.
Pistons - Chrome plated
Made of stainless steel instead of aluminum which can substantially reduce the heat transfer (approx 1/10 of aluminum) from the pad to brake fluid. Pistons are vented to further reduce the heat contact area and improve air circulation thereby reducing more heat transfer. -All of our pistons are chrome plated for additional strength
Our calipers use standard FMSI brake pads, plenty of choice for suppliers and compounds.
Front = D647
Rear = D1368
Weight
Front
RB caliper - 6.0lbs
RB rotors - 15.1lbs
RB adapter - 0.9lbs
Total - 22 lbslbs
Rear
RB caliper - 6.0lbs
RB rotor - 13.2lbs
RB adapter - 0.5lbs
Total - 19.7lbs
Old Jun 6, 2014 | 10:37 PM
moegunz's Avatar
C350
pm me for price
Old Jun 17, 2014 | 02:30 PM
CLS550
PM's Replied,
anyone else interested?
