miles before oil change?
Old Feb 18, 2015 | 10:01 AM
bembden's Avatar
C250
I am new here.
I just purchased a 2012 C-250 for the wife. It has 12000 miles on it. Is there some way I can find out when the oil was last changed? Or perhaps how many miles before the next scheduled oil change? Everything I have read seems to indicate that the oil change reset button is activated at an oil change and one just waits until it tells you to change the oil in 10K miles.
Thanks for the help
Old Feb 18, 2015 | 07:52 PM
Kevin82's Avatar
2012 c250 Coupe
It's every 10k miles. When you reach another 10K it will tell you to change your oil. I have 50K miles on my 2012 and each 10K it reminds me. There is a menu somewhere that tells you how many miles left before next change. Think its under "car assist" or something similar.
After changing the oil, the mechanic presses a certain button combination on your steering wheel to reset the change oil message.
Old Feb 20, 2015 | 04:12 PM
bembden's Avatar
C250
Thanks Kevin
Old Feb 21, 2015 | 12:40 PM
greasykid's Avatar
2015, ML250 BlueTEC
Look in you owners manual. Get to "service" mode on your steering wheel. Remaining mileage should be there.
Old Feb 21, 2015 | 01:57 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Check your maintenance manual for the proper service interval.
Old Feb 24, 2015 | 01:35 PM
bembden's Avatar
C250
I will check tonight when the wife gets home
