Odd door panel stain- What is this from, leak, a/c, spill?
Hi, thanks for checking this post. I just bought a 2014 C 250 20k mi, certified pre owned. When I was in the process I noticed water staining on the inside passenger door panel and asked about it. They said "oh must have been a spill, we'll clean it up for delivery". Well, no its still there and now I am curious where it came from. I attached a couple pictures. What could be the cause of this, and should I be taking this up with the service det? Thank you!!
It looks like water may have wicked up from the door seal. Take a look for damage or deformed material and make sure the door shuts properly. Did you drive through any large puddles or endure a significant precipitation event?
It was like that when I purchased it last week so I am not sure what the history may be. I will have a look to see if any of the door seal material/s look dysfunctional or damaged. I did inspect the door seal on the upper part of the door and that looks fine, and the door does close just fine. Thanks for the thoughts.
