2008 C300 4Matic Transmission Problems
Within the past month or so, the transmission started acting up. Under light acceleration / maintenance throttle, the tachometer bounces back and forth...you don't really feel it "slipping", but you can see the needle oscillating.
Under heavier acceleration, there is a shimmy/shake almost like you are running over tiny rumble strips.
The check engine light came on soon after I realized there was an issue....I assumed low fluid level, but a garage checked that out and also ran a diagnostic and found no engine or transmission error codes indicated.
I had the dealership do all scheduled maintenance until 100K miles or so, so while I haven't verified my records I believe I had the transmission service done. Nonetheless, went ahead and had the garage I took it to change the tranny fluid and filter in the hopes that would fix the issue.
It did not, the garage said the next step recommended by MB is to replace the torque converter. While I was OK with the $350 tranny service, I am not as OK with a ~$1,800 repair when the garage isn't sure that's the issue.
When I pressed the mechanic, he said that given the mileage of the car if it was him he would probably just drive it until failure.
Any other ideas here? The check engine light just came on again today so I'm wondering if the car has finally sensed an issue with the TC...
I gave up my 05 C55 AMG when its tranny was doing funny things at 73k miles. Took in to Helms Bros in Bayside, Queens. They said I would need a new tranny. Their diagnostics was able to compare engine speed to driveshaft speed and it was out of tolerance, hence slipping.
They recommend replacing the radiator then doing the transmission flush at that point. They said issue could be fix with one transmission flush service or as many as 4. From what they experienced in dealing with other benz with the same issue.
I check my self and yes I have a Valeo radiator and it's been a know issue with different C classes.
I call another shop and explained what I was told and that They DON'T recommend doing the flush as in their experience it makes the issue worse. So now I don't know who is right and what to do.
I need to fix the slipping on my car. But in my current situation I can't afford any major repairs and this is my only car for transportation.
Any advice would be appreciated.
