C250 thermostat replacement
2012 C250 Coupe, 2017 C43 AMG Coupe
2012-14 C250 thermostat replacement
Does anyone know how to get to the coolant thermostat on a 2012-14 C250?*
From what I can tell it requires removing the engine air intake tube, problem is I can't figure out how to detach the end which feeds into the turbo.*
Any help, pointers, tips etc....is and would be very much appreciated, only 24,000 miles on my car and already a bad thermostat has me frustrated enough!
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
After air tube---remove upper coolant hose----then remove the poly v belt---then disconnect thermostat connector--then remove two bolts
install--torque for bolts is 25Nm
