Temperature Gauge
Old Nov 19, 2018 | 03:22 AM
mh00's Avatar
2012 C250 Coupe
Temperature Gauge
I have a 2012 c250 coupe with 79k kms. Recently I have noticed that the car temperature gauge takes a long time to reach the 80 to 90-degree mark. Also, it fluctuates up and down sometimes. The heater is running perfectly and takes about 5 minutes to reach an optimal temperature. No issues with the heater in sub-zero Canadian weather. I also have noticed that the car is running a bit rough, rpm fluctuating sometimes while in drive. I am not sure if this is a thermostat problem or the engine coolant temperature sensor problem or something else, coolant level is just a bit below minimum so will be topping that up.
thanks,
Old Nov 24, 2018 | 08:40 PM
ezshift5's Avatar
Mercedes C250 Coupe
All I can offer is it appears you have excellent taste in small, fuel-efficient good looking coupes.
(Will cop to some bias here)
Please do keep us in the loop (about your rough running/thermostat issues.
ez
