used command control module
Old Mar 29, 2019 | 08:30 PM
jenaro's Avatar
2012 c250 coupe
Hi there! I had my command control knob shaft broken as usually happens to just every one as you well know after 4 years of usage, the problem I had is that I repaired the shaft just fine, but unfortunately when i took a part the unit I accidentally broke a tiny little part on the main board and I lost the up and right functions. I wonder if anyone would have a used and broken control module that has the circuit board intact I can buy from?
thanks!!!
