When I changed the spark plugs a while ago I noticed a little oil getting into the spark plug wells. Since I'm now stuck at home like most I took the time to finally replace my valve cover gasket. It went fairly smoothly other then the valve cover being stuck on the engine and requiring about an hour with a rubber mallet and trim removal tools to finally get it to separate. I also noticed when the cover was off that one of the plastic timing chain guides and the hose going from the front bumper to the air filter box had a hole in it. I don't know how important the plastic guide is so I went ahead and replaced it and the air intake hose. I also replaced the grill with a black GTR style grill because the original had cracked and come a bit loose. Took a couple pictures during and after the job that I'll attach below.
