Rear wheels rubbing C63 AMG
C63 w204 2014
Hi
I got some new wheels for my car the size on the rears is 19 x 9.5 ET 45 and the garage used 3mm spacers, not sure if it was for looks for clearance issues
My car is also lowered on H&R springs (they were on car when i bought it)
I have only done about 30miles since getting the wheels but it looks like they are rubbing on the bodywork, like its sticking out too far
Thanks for help
Thanks for help
I have the same problem- but have learned to deal with it for the sake of aesthetics and a wider wheel stance. I have front and rear spacers on my AMG sport C250. When I got new tires, I was told I could go a little wider on the tires- one size up- so I did just that- I failed to tell the tire shop that I had put spacers on the wheels previously. When I hit a dip in the road- it sounds like I'm bottoming out, but after closer inspection, it's the tires rubbing on the body- I have put 30K miles on the tires and they are still structurally sound and safe- you can see a little bit of markings on the side walls, but aside from that it's just a nuisance and sounds bad when hitting those dips in the road. My mechanic assured me all is OK- just sounds gnarly. I have personally decided to put up with it becuase the AMG wheels look so good with the wider look to the wheels. I hope this helps!
