Headliner seperating
Old Mar 10, 2021 | 11:54 AM
chatham's Avatar
c250
2012 C250 and recently the headliner in the back corners is delaminating from the headliner. anyone else have this. any good fixes
Old May 2, 2022 | 08:56 AM
chabbs93's Avatar
c250 W204
yes I have this issue. It will happen in the front of the car same type pillars as well. Anyone know a way to spray adhesive behind it with a needle or any way without removing it? Thanks
Old May 16, 2022 | 04:05 PM
argtv685's Avatar
2011 C300 4Matic Sport
I have that issue in my 2000 SL500. All of the front is down. Im going to try 3M Headliner & Fabric Adhesive. I may have to put a little hole in the headliner to get the spray in but that will be better than having it hang down!
Old Jan 30, 2023 | 04:42 PM
chabbs93's Avatar
c250 W204
curious if it has worked for you?
Old Mar 13, 2023 | 05:30 PM
MAKO314's Avatar
2014 c63, 2014 c300, 2015 SL550, 2000 F350 psd
The cause, sunroof vents leaking. Occasionally blow them out gently with compressed air, the empty in the rear wheel wells just inside. The fix for the headliner is adhesive with a syringe, little small shots all over the spot that has fallen. Squirt, tap up, let fall again for a min or so then press it up and smooth it out. This will darken the lighter colored headliner material but just a little. The best fix is a new headliner but few of those repair guys have the exact match material. I just had mine done in the 300.
Old Dec 10, 2023 | 08:21 PM
ktmrider203's Avatar
2014 MB C250
2014 C250 coupe - headliner delaminating at rear
MIne been doing for 3-4 years in rear but its slow so letting it ride . Agree the 3M headliner adhesive worked well on other cars so may try it . I have kept sunroof drains clean so I think its a systemic problem on C250 coupes. Drivers seat covers will split - is a DIY job , see you tube for C250 coupe since it has NeckPro headrest is a very specific procedure unlike the 4 door C cars. And seat handle breaks on a lot of C class coupes which is in DIY you tube how to .
Old Dec 19, 2023 | 04:36 PM
ezshift5's Avatar
Mercedes C250 Coupe
My headliner - 2012 C250 coupe - is without any visible (at least to me) issues.
Would
sunroof non-use possibly be a factor here?
CPO car - only one issue since 2014 purchase (ESL)
Holiday's best,
ez
