C300 4matic 2008 electric issues after rain
Old Jun 5, 2022 | 09:52 AM
DannyZ's Avatar
2008 c300 4matic
After it rained the end dash nav kept turning off and back on randomly, dashboard said check right and left rear tail lights, tail lights were fine no bulbs were burnt blinkers worked fine but blinked fast inside, and gas gauge stopped working. There was water in the trunk and water under driver side floor panel. I checked the wiring underneath the floor panel on the driver's side and the distribution block had corrosion on it I tried lightly cleaning it with electronic cleaner and a toothbrush after that many errors came up on the dash and the car will not start, I replaced the distribution block and same thing vehicle will not start and has many errors U0155 with scanner. Please Help Me
The car started before I cleaned this distributor block, after it didn't start I replaced it. Car won't start.
My 2008 C300 4Matic
