2014 C350 Sport Coupe
Old Aug 5, 2023 | 05:55 PM
geezer392002's Avatar
2014 C-350 Coupe
Hi,
I wanted to ask for some advice on a vibration problem I’m having with the car. The car is 2014 with 58K on the clock. The vibration/shudder seems to go through the whole car not the steering and seems to occur between 40-55mph.
I have not taken it to the dealership yet as the nearest one is about 2 hours away, but I had a well regarded Indy do a transmission drain and fill. The original ATF was still very clean with no metal pieces on the magnets.
I had the shop reset the adaptive learning but that has not helped.
Any advice would be most appreciated and Thanks in advance!
Here are a couple photos of my car 😄
Old Nov 26, 2024 | 11:56 AM
DavGry52's Avatar
C204 C350
These cars aren't hugely complex. I can't see a reason as to why your Indy wouldn't be able to check this over for you.... Are the rear wheels balanced? That would be a vibration through the car. Are the rear tyres feathered/wearing unevenly? Up on a ramp, is the diff hot after short drives, do the prop-shaft donuts look in good condition?
Old May 23, 2025 | 11:18 AM
clkcdnfirstbenz's Avatar
CLK 320
I have the same car and it drives like a dream.
Vibration is usually a wheel/tire issue and sometimes it can be a brake rotor/pad issue.
If you are going to keep the car, then perhaps making a trip to the dealership might not be a bad idea.
It's a Mercedes, treat it right.
