2014 C350 coolant low warning error?
Old Sep 9, 2023 | 07:34 AM
geezer392002's Avatar
2014 C-350 Coupe
Hi guys,
Just wondered if you’ve had a coolant level warning error? I just had the B service done at 55K and almost straight after I got a low coolant warning. I checked it and it wasn’t low but I topped it off. A week later after only driving about 10 miles the low coolant warning comes on again. I checked the level and it has barely gone down from when I topped it off.
Could the warning be false?
many thanks!
9/12 update
took the car to my local stealership as the tranny is also shifting rough and there is the common shudder at various speeds. The service department claims the radiator leaked fluid into the transmission and screwed it completely. So I’d need a new transmission, torque converter, radiator and coolant tank.
Not sure I believe them TBH, any thoughts guys?
Old Sep 23, 2023 | 07:00 PM
C280 Sport's Avatar
MB’s of all kinds.
Sounds very much like a sensor is off in the coolant reservoir. Try to see if you can tighten the coolant cap first.
Old Sep 23, 2023 | 08:37 PM
2014 C-350 Coupe
Re: 2014 C350 coolant low warning error
Thanks for your reply C280.
Unfortunately it turned out to be coolant leaking into the tranny.
Yet another victim of the faulty radiator that has cost many MB owners a lot of money.
I believe earlier C-Class model owners ended up suing MB for damages. Are there any other later model C-Class owners (2012-2014) on this forum who have damaged trannys due to faulty radiators?
