Head Pounder
I have a 2014 Mercedes Benz C250 I installed a new coolant pipe on the rear of the engine. I have to remove the battery cables, Intake plenum, Oil Filter housing, Starter, and High Pressure fuel pump. After completing the repair, and total reassemble of the everything, the vehicle key fob through a replace the key fob battery. I installed new battery, and everything powers up but won't start. I removed starter to verify correct install, and it was right. I checked codes, and got a steering lock fault. Before sending to the dealer, I wanted to make sure there was nothing I'm missing. I've reset the ESC system multiple times by disconnecting the battery. Everything powers up, I don't hear the steering lock release, and it only moves a little bit. Please help
