Trouble with lighting delay
Old Sep 12, 2016 | 02:34 PM
flycaster's Avatar
2017 C300 Coupe, 2013 Cadillac ATS 2.0T
Trouble with lighting delay...SOLVED
When exiting the car (after doing some adjustments within Vehicle>System in which I didn't start the car, but just pressed the start/stop button once,) but not locking it, the tail lights, front directional signal lights, and the LED strip stay on for a long time (greater than 60 seconds), as does the interior dash and MM screen. Not sure how long the lights will stay on as when testing, I shut them off after 60 seconds so as not to drain the battery. This happens even though I have correctly turned off any delays for interior and exterior lighting. The manual says that turning off these delays has the lights going out within a short time...certainly less than 60 seconds. This also happens when I've set the delays for 15 seconds. However, locking the car does turn off all lights.
I have just spoken to the MB concierge and he said that he hasn't come across this situation. He then checked with a tech using a 2017 coupe, and the lights do go off when the car is exited...but not locked. The tech said to bring the car in for evaluation...ugh! Anyone have a clue as to what may be happening?
EDIT: I think I just had a brainstorm, or a brainfrt, not sure yet, but rather than just pressing the start/stop button once to get juice into the electrical system, I started the car, shut it off, and exited without locking...and the lights went out immediately (remember all delay setting were on OFF.) So, it could be that the lights stay on longer when the engine isn't started, but act appropriate to their settings when the car is started??? Ah, yes, that may be the way it is. As a final test, I started the engine, and reset the delays to from 0 to 15 seconds, shut the engine off and got out of the car. Lo and behold, lights went out in 15 secs.
I'm now in the process of telling all this to the concierge so that he can relay it to the tech. Of course, if this is new to the tech, then I'm going to be quite leery of having work done by the tech.
EDIT2: When the tech did the testing, he had the engine on...this confirms what I have found out. However, another fly in the ointment is that I only did one press of the start/stop and perhaps I should have done two presses? Now HERE'S IS THE SOLUTION to the whole issue:
If you want to change/modify your car's setting, but you DON'T want to turn on the engine, then you press the start/stop twice as this will fully turn on the electric system. Do your settings changes and before you leave the car, press the start/stop one more time. This will turn off the system and everything will (should) work according to the settings. My error was that I failed to shut everything down by not hitting the start/stop a third time. And, the reason that all lights went out when I locked the car is that locking obviously will also shut down everything.
Old Sep 12, 2016 | 04:15 PM
flycaster's Avatar
SOLVED
See solution in EDIT 2 in original post
