Start - Stop
Old Sep 6, 2018 | 04:34 PM
dak911's Avatar
BMW 530 xiT
Start - Stop
This feature is the MOST annoying thing ever
Is it possible to defeat this without having to push the button every time you start up?
Old Sep 7, 2018 | 06:39 AM
guhvies's Avatar
2017 C43 AMG Saloon
There's a module for that. Use the search in the main W205 forum.
Old Sep 9, 2018 | 02:38 PM
Louis300's Avatar
C300 4matic Coupe
Go to EBay and search for Mercedes Eco Start Off. You plug unit into car Diagnostic port the unit will change programming not to auto start Eco Start every time you start car. Eco Start will still work if you press Eco start button in car.
Old Sep 9, 2018 | 03:32 PM
dak911's Avatar
BMW 530 xiT
$120 to disable eco start.... I think NOT. I'll just push the button each time..Thanks anyway..
Old Sep 13, 2018 | 12:26 AM
Q7tany's Avatar
mercedes c300 coupe 2017
What I did was I just went in the settings and configured the individual mode as per what i wanted and when i came to auto stat / stop just disabled it
the dawn side of it was every time start the car after a long time off had to put it in the individual mode
Old Sep 14, 2018 | 11:25 PM
AMG C43 3LV6's Avatar
AMG C43 3LV6
Same I was going to buy the module then I thought I usually make a decision each time to turn on the PE, so pressing the button next to it, is not an issue.
The module effectively gives you a dead button for eco stop start.
Old Nov 3, 2020 | 12:11 AM
gtg413i's Avatar
C300 A205
I bought the module. Definitely worth it. That start / stop will add more wear and tear costing more than $120 to fix in the long run. Now if they could only give you a memory for the last drive setting. There is an option for it to have a 4 hour memory on whatever mode you select.
Old Nov 3, 2020 | 02:33 AM
AMG C43 3LV6
I never thought of that. Its a good point. I never ever have used it.
Old Nov 3, 2020 | 03:16 AM
Gazwould's Avatar
S204 C250 CDI Sport
Premature wear of engine mounts , timing chain and tentioner , alternator , ring gear , starter motor , battery and engine .
Old Mar 11, 2021 | 06:30 PM
midcityeng's Avatar
PREMIUM SPONSOR
2013 SL550, 2016 GLE350, 2016 GLC300
For anyone annoyed with disabling the start / stop feature each time, you can pick up one of our OBD programmers that retains "last mode" for this feature, you can take a look at our vehicle coverages HERE. Pick one up today!
Old Mar 12, 2021 | 09:52 AM
Louis300's Avatar
C300 4matic Coupe
I purchased MidCity Engineering Eco Off Programer for a 2020 Mercedes Benz C300 Coupe. Very easy and works. I tried other Companies plug in programmers, they did not work.
Old Mar 12, 2021 | 01:00 PM
smbsocal's Avatar
'21 C63S Cabrio, '21 Corvette C8, '18 BMW X5
I hate the fact that you cannot set the default for the Start-Stop yourself without some sort of third-party programming. I would love to get the Eco Off module but worry that it would show that the ECU was modified if the worst happens and I had to have powertrain warranty done.
Old Mar 12, 2021 | 01:30 PM
Louis300's Avatar
C300 4matic Coupe
It will not show it is modified it checks used lat setting in Mercedes Benz OEM software. The dealer can check this off using star computer but they will no do it. When you bring in for service just press eco start stop button it will turn it back on. When service is done press eco start stop button it will turn it off again.
Old Apr 4, 2021 | 11:39 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Originally Posted by motorhead4matic
It's ironic. Start-stop feature supposed to reduce fuel consumption and emissions but turns out to be annoying instead
From what I’ve read, it’s less annoying than some. I don’t have the car yet. The manual says it doesn’t stop at stop signs.
Old Apr 5, 2021 | 06:04 PM
Louis300's Avatar
C300 4matic Coupe
It stops every time you stop car for more then 30 seconds.
Old Apr 5, 2021 | 08:12 PM
In my bmw, the engine stops almost immediately. I leave it off.
Old Jun 21, 2021 | 07:01 PM
GabrielFSousa's Avatar
c205
what module to disable in a c205 year 2016 ?
Old Jun 21, 2021 | 07:38 PM
Louis300's Avatar
C300 4matic Coupe
Go to midcityengineering.com. They have a module that plugs into the diagnostic port and reprograms
the eco startstop to stay off once you press the eco start stop off button even when yo restart.
