TIRE PRESSURE C205 C43 AMG COUPE 2018
I was just wandering what is the ideal tire pressure for a 2018 coupe? Its Summer in Australia and I just drive mainly by myself or a passenger and she is light lol. like 50kgs.
I found some info below about it but was curious what others have. Didnt even know there was a difference between Summer and winter, mind you in Australia our weather is not extreme. ie snow.
I did search other threads, but couldnt find a proper title which I think is half the problem with a lot of these thread titles in terms of searching for information.
However, remember, pressure range can fluctuate. The lower range of pressure is better for colder temperatures, and the higher range of pressure is better for warmer temperatures. Additionally, more weight from cargo and passengers in your vehicle means your tires will perform better with higher tire pressure. Therefore, if you typically drive by yourself, chose a psi from the lower range. Meanwhile, if you typically have passengers and cargo, chose a psi on the higher end.
2018 Mercedes-Benz C-Class Tire Pressure Levels
First, let’s take a look at the tires on the 2018 Mercedes-Benz C-Class modelsThe wheels and tires included on the baseline model of the 2018 Mercedes-Benz C-Class sedan are measured and cataloged as 17″ split 5-spoke wheels with 225/50R17 all-season tires.The wheels and tires included on the baseline models of the 2018 Mercedes-Benz C-Class Cabriolet and Coupe are 18″ twin 5-spoke wheels with 225/45R18 all-season front tires and 225/40R18 all-season rear tires.- 225/50R17 tires for the 2018 Mercedes-Benz C-Class sedan have an ideal pressure range of 32-40 psi (pounds per square inch).
- 225/45R18 front tires for the 2018 Mercedes-Benz C-Class Cabriolet and Coupe have an ideal pressure range of 33-39 psi.
- 225/40R18 rear tires for the 2018 Mercedes-Benz C-Class Cabriolet and Coupe have an ideal pressure range of 32-41 psi.
Was advised to have them all at 38 PSI.
