High LTFT (Over 30%)
Old May 25, 2026 | 02:49 PM
fxx's Avatar
fxx
C180 Coupe Sport 2019
Hello,
I have a 2019 Mercedes C180 W205 and I've been fighting high fuel trims for over a month.
The issue started after a 400 km trip where the car entered limp mode with a cylinder 1 misfire. Spark plugs were replaced and the misfire never returned.
Later I noticed:
  • LTFT around +25% to +45%
  • P2177 lean code
  • car felt heavy/sluggish
  • battery voltage was very high (14.8–15.1V)
I replaced the battery and idle became smoother, no much vibration, and lower map values on idle.
I also noticed the pre-cat O2 sensor (O2S1) was barely reacting, so I replaced it. After that:
  • car became much smoother
  • P2177 never returned
  • STFT behavior became much more normal
I also had these codes before changing the battery:
  • P007D (intercooler temp sensor circuit high)
  • P0238 (boost pressure sensor high input)
  • P1190 (Intake Air Pressure Sensor Fault)
Because of that, I replaced the MAP/TMAP sensor too this weekend.
Now
  • no limp mode
  • boost feels smooth and linear
  • car drives much better overall
However, LTFT still stays high around +28% to +32%.
I already reset fuel trims around 5 times and even disconnected the battery for over 1 hour, but trims always come back high after driving.
Additional info:
  • O2S1 now oscillates normally
  • MAP idle = 4.5 psi - 5psi - and it gos up to 31 psi on WOT(total)
  • O2S2 stays around 0.7V
  • STFT is usually close to 0% when driving
    • STFT negative on idle (-10 to zero)
    • STFT negative in some pulls (-2, -3)
    • STFT positive in some hard pulls (7-8 intant then downs to 3-0)
    • STFT positive in high gear around 80kmh but not always
  • fuel economy is around 7 km/l city and 15–17 km/l highway (for city is not good and car feels like heavy)
At this point I'm trying to understand:
  • do I still have a real lean condition/vacuum leak?
  • or did previous sensor/electrical issues corrupt the fuel/load adaptations?
  • why car sometimes feels like i have 200kg extra weight?
Any ideas what I should check next?
File Type: csv
File Type: csv
File Type: csv
