Wiper comes on when i use turn signal!!
I had the same problem. It's very easy to repair it. First open the fuse-box, then there are four scrws around the fuses unscrew them and when you remove the cover you'll see two big relays. The one on the engine side, it's a smaller one has to be replaced.
Luck
