c280 vacuum hose
c280 vacuum hose
I need locate the vacuum hose for my c280. The reason that I am asking this is that I got an oil change and believe that my vacuum hose has been disconnected. This has happened to me before and I don't want to go back to the repair shop and would like to do this on my own. Any suggestions?
thanks!!!!!!!!!!!!!
thanks!!!!!!!!!!!!!
2001 E320 (210.065), Brilliant Silver; 2002 Ducati ST-2, Arrest-me Red
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
If you're car is running funny after an oil change, I'd really take it back to them and complain. It might be something much more complex than a vacuum line and if you start trying things then they're likely to say you goofed something up.
If you want to proceed, however, and you're pretty sure it's a vacuum leak, know that there are several vacuum hoses under the hood. The easiest way to isolate it is to take a length of hose (vacuum will work) and slightly insert one end in one ear. Remove the plastic engine cover and then with the engine running -- be careful not to catch you, your clothes or anything else !! -- you can move the other end of the hose slowly around the engine. The hose will work much like a stethoscope and help you locate the hose. (You'll clearly hear the hiss/whistle when you're close to it.)
Good luck and enjoy the ride,![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Greg
Greg
