94 C280 Window Reprogram/Convenience Features
All the reprogramming directions I've found online are for the "one-touch" windows that came on the 96-2000 w202's. Apparently many are un-aware...
94-95 w202's have differences from the rest. Only the front windows have auto-roll, but only on rolling the windows DOWN. The rear windows have nothing automatic. Also, the sunroof is not automatic and the button must always be held.
Still, I would love to get the auto-down feature working again on my 280. Also, there are other features that were deactivated once I disconnected the battery.
When you exit the vehicles with windows down (or sunroof open), then insert the key, lock doors, and hold key; it automatically closes the windows/sunroof. Well, this needs to be reset/reprogrammed also.
I've rolled the windows all the way down on first level of the button, then once the windows reached bottom, pressed the button a little harder to engage the second level of the switch (the auto-roll-down) and held for 10 seconds. I hear a click inside the door right at the 10-second mark. I roll back up and do the same, and it doesn't help. I'm not sure what's going on, except for maybe the 94/95's needing different technique to reprogram (seeing as how it has a different switch/body harness).
i had to reprogram the sunroof which in turn fixed the windows...
press the up (flip up roof) button and hold for a like 5-10 seconds and you will hear a click... windows worked after that... good luck man
I've played around with the windows and I can tell there's a definite procedure to it. I just can't figure it out completely.
