C220 Engine Timing Problems!! Please Help!!
Old Aug 17, 2005 | 01:22 PM
amgv12biturbo's Avatar
I hava a 1994 C220 with 155k miles. Almost everything has been done to it (air flow sensor, o2 sensor, throttle opener, spark plugs, engine wiring harness, coolant, belts, hoses, and oils). I have a question. Can someone please help me locate the timing marks on the camshafts when cylinder 1 is on the top position (on P on the crank or whatever that letter is). I have a feeling the timing is off, because my engine vibrates really bad and makes weird noises. I think the camshaft skipped a gear, and I want to make sure that the timing on my intake and exhaust camshafts are where they are suppost to be before I do anything else. Please help me find those marks!!! Any help would be greatly appreciated!!! Thanks!!!
Old Feb 22, 2011 | 04:41 PM
alexbenz43's Avatar
c220
timing
I have the marks, do you need it?
alexanderboyer3@hotmail.com
