Old Jun 10, 2015, 03:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How to replace the battery in the remote control
Rating: Thread Rating: 2 votes, 5.00 average.
Old Sep 17, 2005 | 02:26 PM
crystaldon's Avatar
It took me a while to figure this out, so I thought I would pass it along. This is how to change the battery on you remote control (this is on a 1999 C230)
1. Remove the metal spare key from the remote control.
(Slide the catch toward the Panic button and push the metal key tab toward the rear, remove the metal key completely from the remote.)
2. Hold the remote control and look at the edge that you just removed the metal key from (with the wide end up). Look at the top of the key slot. There is a catch that moves into the remote when you push on the slide at the top of the remote. This is the catch that holds the metal key in the remote. It's black. Immediately below the black catch (about 1/4 inch below) is a white catch. You will need to push the white catch in to remove the battery holder.
4. You will be removing the entire wide end of the remote control from the rest of the control. This is the part of the remote that has the Panic button and the metal key slide button. It also has a slot around its edge for your fingernails to fit into.
5. Use key end of the metal key to push the white catch into the remote.
6. Use your middle fingernail and thumbnail in the edge of the battery holder and pull up on the battery holder. Wiggling the holder helps. Pull up the metal key end of the holder first, then the other end.
7. Be careful while removing the battery holder. The battery might fall out if it's upside down.
8. Replacing the battery and reassembly should be fairly staight forward.
Good luck,
Don
Attached Thumbnails How to replace the battery in the remote control-img_0177a.jpg   How to replace the battery in the remote control-img_0183a.jpg   How to replace the battery in the remote control-img_0186a.jpg   How to replace the battery in the remote control-img_0188a.jpg
Old Sep 20, 2005 | 07:26 PM
maho1975's Avatar
1995 , C220
cheers for that !!!!!
Old Jun 30, 2011 | 01:03 PM
veba911's Avatar
w210 1998 e200 avantgarde
do you need to synchronise the remote with car after you replce batterys and if so how ??
thanks
jason
Old Jul 1, 2011 | 02:42 PM
alliv's Avatar
mercedes c250
does anyone know how its done on the chrome edged key?
Old Jul 3, 2011 | 05:09 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
thanks
jason
Synchronizing Remote Control:
The remote control MAY have to be resynchronized, if the vehicle cannot be locked or unlocked. To synchronize, simply insert the electronic key (remote) in steering lock (ignition). The remote control should once again be operational.
Old Jul 23, 2013 | 10:08 PM
hand's Avatar
04 C230 Kompressor
Video how to
Thanks for sharing. Helped me figure it out, so thought I would share a video version.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
