air blower/lcd clock segments/maintenance q's
C220 CDI Sport
hi, i've been away awhile and come back for some help medicine, doctors.
lately my excellent 00 22o cdi has had two or three niggles that need sorting out please.
1- the ac blower has lately, i noticed, been blowing low pressured air thru vents, even when the manual dial is on max[with either hot or cold setting].
i checked forum, and talks about cabin/pollen filter, i will check. could it be anything else i should check?
2- from the outside, i hear slightly louder engine noise like the noise of a belt but cannot fig what it is. ok its a diesel, but more noisier than normal. any common concerns.
3- im coming up to my first oil change since i had this car. i know what grade to use, but any recommends on brand/quality, good for performance and econo. shall i stick to recomend grade or a different viscosity better? whats brands of filter do you diesel owners go with for oil/air.
4- back inside, the lcd clock is not showing up all the segments so the numbers look confusing. whats the cause & how to fix/cost. it lights up ok along with the rest of gauges, just the segments.
thanking you in advance.
dave
dave
