FSS (B) Service
1 Post
Mitsubishi Outlander 2012 AWD
Safety inspection/removal inspect measure rotors/replace fresh air filter/overall inspect serpentine belt/driveline/road test/quick short test for codes in vehicle/battery load check/electrical consumer functions/seat belt operation Ask for a service sheet from dealer
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Flexible Service System - A-Service
What we do:
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
*Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
Flexible Service System - B-Service
What we do:
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
My dealer wants $250 for A, and about $400 for B. I bought this car used, so I'm like 'no thanks'. I find a good indie place that will do what I want.
I don't need to pay someone to "ensure that horn is working".
What we do:
What we do:
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
