replace battery?
Old Jan 22, 2006 | 08:04 AM
jimsaco's Avatar
replace battery?
Perhaps I am a fool but I let my 96 C220 sit for 3 months without attention. It ran great prior to sitting -- no particular problems. When I went to start it yesterday -- Dead! So I jumped it and let it run about an hour. Figured that would suffice. Shut it down. Tried to restart -- Dead!
I don't know how old the battery is, it may be original to the car for all I know as I am the second owner. Hasn't been replaced in the 3 years I've had it anyway.
Is there some sort of special battery the car needs, or will a good quality one from Autozone do the trick?
Also are there any particular tricks to putting a new one in?
Thanks all.
Old Jan 22, 2006 | 10:27 AM
KarlBenz's Avatar
Mitsubishi Outlander 2012 AWD
Any good 450 amp hour battery should work Sears is good when staring need to initialize steering angle sensor (turn wheel lock to lock) code radio/synchronize sunroof(push button up and hold) and synchronize windows thats all
Old Jan 22, 2006 | 11:01 AM
jimsaco's Avatar
windows?
What does synchronize windows mean? Forgive my ignorance.
Old Jan 22, 2006 | 11:42 AM
JOESID's Avatar
Well when you cut the power, you will notice afterwards that your auto-up/down feature for the windows doesn't work. Its very simple;
1) Lower window manually using the button.
2) Raise window manually using button.
3) Hold the button in the "raise" position for a few seconds after its reached the top.
4) Repeat for other windows.
5) Enjoy your auto up/down function again
Old Jan 22, 2006 | 11:44 AM
JOESID's Avatar
I haven't had to change mine yet (knock on wood), but I would just go to sears. If you go to the auto area, I'm pretty sure that they can look it up in their computer. Or, if you go to thier website, you can do it there and call ahead.
Old Jan 29, 2006 | 05:11 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Thanks all.
Before you replace the battery, the next time it's jumped, check the voltage
across the battery when it's at idle. I think it should be around 14.3 volts. I'd
see if the alternator is working properly before changing the battery.
To answer the question, it's easy to replace. You can do it yourself. I have
Sears Diehard International battery and it's fine. Just make sure you have the
piece to vent the battery outside the lower trunk area.
Old Feb 4, 2006 | 04:58 PM
jimsaco's Avatar
thanks
Put in a new battery from Advance Auto -- at a good price. All seems to be in order -- windows and sunroof all work etc. Been driving it the last week and runs like a charm. Thanks to all.
Old Nov 30, 2006 | 10:14 AM
brito's Avatar
C200 Kompressor
Great post!
Thanks for this information!
I was having strange problems a couple of days ago (windows, ESP/BAS warning light) and suddenly my battery went dead. After I replaced the battery yesterday the ESP/BAS seems to be ok, but the windows, arghh.... (
I never thought that windows had to be synchronized!
Old Nov 26, 2007 | 12:18 AM
V A N Q U I S H's Avatar
1998 Mercedes C230 Elegance
THANK YOU! You are a lifesaver.
Oh, and hello MB World - first post!
Old Nov 26, 2007 | 08:02 AM
Untertürkheim's Avatar
Thanks all.
You very well may not need to replace your battery. First, what kind of battery is it? If it is a original MB battery, it probably has serviceable cells. If one or more have dried up, you may be able to save your battery by simply refilling all of the cells with distilled water and charging the battery (a battery charger is a good thing to have anyway). If it is a service-free sealed battery, you can simply try charging it and see if that helps, since it may be your alternator anyway, in which case a new battery would be a waste...
