need help!!!
Old Mar 18, 2006 | 10:42 PM
K_ching55's Avatar
need help!!!
Hi i have a 95 c220 and its been giving me a hard time. Everytime i have to make a left turn or a right turn, the cars makes a rubbing sound in the front. I mean my car is not drop low or anything, its totally stock height. Anyways if you can help let me know thx.
Old Mar 20, 2006 | 05:27 AM
shandy2550's Avatar
1995 c220 auto
If your car has not been lowered as you say, are the tyres and wheels standard ?, 205/65/15 is the standard. If non standard wider wheels have been fitted, or with a different offset ,they may rub on the suspension parts. Jack the front of the car and spin the wheels while holding the steering to full lock and you should be able to see what is rubbing.
This should be fixed as a matter of urgency as it could cause a tyre to blow out or some other failure.
Geo.
Old Mar 20, 2006 | 12:51 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
CORRECTION 195/65/15 is the stock tire siz on on your car.
Old Mar 20, 2006 | 05:28 PM
shandy2550's Avatar
1995 c220 auto
Apologise, should have said 205/60 R15.
There are 3 alternative stock sizes for 1995 C220 : 185/65 R15 ,or 195/65 R15 ,or 205/60 R15.
As I said,you need to check underneath to see what is rubbing before you have a problem, good luck.
Geo.
