Radiator leak
Old May 5, 2006 | 04:50 AM
rmt6668's Avatar
Radiator leak
Hi,
My 1995 C220 developed a small leak from the Radiator. I have taken a pic from top elevation.
Can any 1 advice me where the leak from?
Kind Regards
Old May 7, 2006 | 03:08 AM
rmt6668's Avatar
There seem to be wet near the pulleys, near the water pump. Is this a water pump leak or its a normal discharge by the water pump due to cooling system prob (like a leaking Radiator/loss of pressure?)
Can I top up my coolant & drive to my mechanic?
Old May 11, 2006 | 07:27 PM
rmt6668's Avatar
Engine Mounts Broken
Hi,
The mechanic have now replaced the Water Pump & new Radiator. Question is theRadiator look new from inside the engine bay but externally, where the 2 fans connected is still same. Is that the Air Conditioner/Heater Radiator?
Also mechanic spotted that the engine mount is broken. I know one mount already replace last Aug, coz when car put on reverse it vibrate tremondously, so only 1 mount replace is that the left or right mount. Now this mechanic say "Engine mounts broken". Is it that he observed one broken mount & concluded/assumed the "plural". Whats will occur if that one mount is not replaced?
Kind Regards
