car problems
When the car is warm, and i come to a stop, mostly when the A/C is on,
the idle surges. The eng harness is new, the coolant temp sensor, the
over voltage protection relay, a/c pushbutton control module, a/c compressor. I check fuel pressure - good, and i check for vaccum leak - none.
Any one got any ideas
Clean the butterfly valve and throat of the valve using a solvent, IPA or carb cleaner.
See here for location #80 on the first diagram,http://www.detali.ru/cat/oem_mb2.asp...SGR=040&SGN=01.
Hope this helps,Geo.
it also does it when moving from P/N to D/R exspecially with a/c on, theres no check eng light on - no codes
Ive checked cam adjusters, vaccum leaks, ive put a new ME (eng computer), M16 motor (throtle control & idle control), check fuel
pressure, checked fuel pressure regulator, new coils, new coil
harness, over voltage relay, coolant temp sensor, ac compressor,
new eng harness, new mas, new spark plugs, suppresors, plug
wires, plug wire ends at coil, hooked up to a scope and check
the ignition pattern - good, cleaned intake, adjust throttle and idle linkage
any ideas would really help
thanks
__________________
thanks
