Power Antenna
Old May 26, 2006 | 12:22 PM
Teddy's Avatar
Power Antenna
hey guys
I have a 98 W202 C200 Australian delivered model and I have just changed the stock head unit (Eurovox) with a swish new Alpine Head unit cd player/mp3.
Now my problem is, everytime this unit is on (even when Im listening to cds) with no need for the power antenna, it still goes up!
is there any way to make the antenna stay down, when I am listening to cds and only go up when im using the radio (which isn't much)
Is it an easy fix or is it impossible
Thanks for all your help!
Teddy.
Old May 26, 2006 | 04:43 PM
shandy2550's Avatar
1995 c220 auto
It may be that your head gives an antenna signal whenever it is powered up, I just changed from a Sony single CD head which did this, to a Sony radio cassette head with cd multi-changer which only activates the antenna when the radio is on, so obviously there are different signals from different units.
I fitted both these units myself and there was no obvious way to alter the antenna signal on either unit.
Cheers, Geo.
Old May 26, 2006 | 04:44 PM
MattB's Avatar
1995 Infiniti G20tA
Crutchfield may offer a power antenna adapter, I know they do for other cars. www.crutchfield.com
On a side note, power antennas suck. They get stuck halfway up, halfway down, and generally look ugly.
Old May 29, 2006 | 12:14 PM
shandy2550's Avatar
1995 c220 auto
Teddy,
I just checked my head unit and found that with the traffic alert(TA) function enabled the antenna extends every time the unit is on,do you have it enabled ?
Geo.
Old May 31, 2006 | 12:06 AM
LeftCoastBias's Avatar
i've lost count
i think our stock merc stereo still keeps the antenna up when we're playing cd's?
Old May 31, 2006 | 12:57 PM
harryt's Avatar
95 C280
Mine does the same, I am installing some subz. So what I did is just disconect it in the trunk. Just take out the antenna power wire. It slips in and out, so it requires no cutting or any damage. I hardly use AM radio, sometimes FM and mostly my CD music.
Old Jun 2, 2006 | 02:46 AM
Teddy's Avatar
Originally Posted by shandy2550
Teddy,
Geo.
I turned off TA and my antenna still stays up
Old Jun 2, 2006 | 02:52 AM
Teddy's Avatar
can you show me a pic of where it is located and which wire to pull
Old Jun 11, 2006 | 07:08 AM
Teddy's Avatar
Hi, does anyone know where the antenna power plug is in the boot?
I cant seem to find it, is it hidden behind all that material?
Old Jun 12, 2006 | 07:00 AM
shandy2550's Avatar
1995 c220 auto
Yes, it's behind the boot lining on the same side as the antenna. The plug is on the body of the antenna motor drive unit.
Your's is probably that shown in the first diagram here , no.80, Hirschmann.http://www.detali.ru/cat/oem_mb2.asp...SGR=345&SGN=21 .
Old Jun 14, 2006 | 11:15 PM
Focus on this 1's Avatar
Clk 55 04
if you dont listen to radio just unplug the antena from the trunk
Old Jun 16, 2006 | 02:50 AM
Teddy's Avatar
Yep guys, I finally found it in the trunk!
pulled the power cable out and now its all good
