Electrical Problems on '99 C280
My father owns a mint condition '99 C280 and he takes care of the car extremely well. Last week the car started having problems with the front windows; they would not move and then after several tries they might go up and down. Today the problem extended to the doors, the remote key no longer works, it won't open or close the doors. The sunroof, the mirrors and the remote key for the garage door don't work either. The rear windows seem to work fine though.
I hope you guys will be able to give me some advice,
Thanks in advance for your help,
Raxhi
I had one last week-same complaint exactly- try explaining that to a customer " I know the rear windows work OK, but it needs a LR window regulator to fix the front windows"....
I'm taking my car back to the shop tomorrow so they can have it for three working days. I'm also going to mention what I read in this thread. Thanks for the info everyone. I'll let you know the resolution. After that, I need to have a headliner replaced that started sagging last week. When it rains...
1999 C280
When the car came back from the shop, everything worked fine...for four days. Then everything stopped working again (windows, mirrors, moonroof, remote sensor...). I'm taking it back in next week. If they can't reslove the problem, then I'll be going to the local Mercedes dealership.
Last week, my mechanic found some wires under the hood that had oil leaking on them. It must have been a small amount of oil...he couldn't locate the leak, and I have no oil drops in my carport. He wrapped the wires in felt and tape and everything works fine.
In retrospect, it seems that perhaps the problem was not the CAN bus.
