code P0443 on 98 C-280
Old Sep 4, 2006 | 04:17 PM
solidgold6's Avatar
Hi,
Engine service light is on, code P0443 which is Purge Control Valve. I need help locate Purge Control Valve.
Thanks.
Shah
Old Sep 10, 2006 | 06:58 PM
MBHustla858's Avatar
its probrably ur regeneration valve, which is on the left side of the engine bay. once you remove it, you should vacuum test if and see if it holds... if not, replace it
