SRS indicator lit
Old Oct 6, 2006 | 02:24 AM
topgun68's Avatar
Angry SRS indicator lit
I just got my battery changed but after i connect it, the SRS indicator lit at dashboard. I can't get it off till now. Can anyone tell me what could be the problem.
C180 95'
Old Oct 10, 2006 | 05:04 PM
bcmiguel's Avatar
1999 C230 Kompressor Sport
because you changed your battery and the voltage droppped it sets off the SRS light, not a big deal, just gotta go to a shop or dealer and have them reset the computer, the only thing now while the light is on is that the Airbags will not deploy in an accident, so when you got a chance swing by your mechanic and have them reset the computer, had the same thing happen to me...
Old Oct 11, 2006 | 09:54 AM
shandy2550's Avatar
1995 c220 auto
(because you changed your battery and the voltage dropped it sets off the SRS light,)
Not true ,or every time a battery had to be disconnected for any reason the SRS light would be activated!!!!
The only reason the SRS light is activated is if there has been an interruption in the SRS power loop due to activation, a faulty sensor or some SRS component being disconnected when the ignition is switched on.
The warning light has two modes; if it illuminates and goes off after 2 minutes you have a non-critical fault stored and your SRS system is still operational , but if it illuminates and does not go out after 2 minutes you have a critical fault and the system is non-operational requiring fault rectiflcation as soon as possible.
Geo.
Old Oct 16, 2006 | 11:23 PM
arslanm3's Avatar
mercedes c-class 200 1995
its one easy step..
you have to reset the car's programing, then, referesh the sotware. you only needa good garage with the exact MB. software, just plug a Laptop Computer by a special plug to your car's computer board and do the job, But dont worry its not A BIG problem
